07-08-2024
07:55
05:17
07-08-2024
07:55
05:17
Why does my Versa 4 only charge to 99%?
Best Answer07-09-2024 05:27 - edited 07-09-2024 05:58
Hi there, @pattyirene. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention. We're here to help you!
Have you tried the tips and recommendations provided by @Guy_? The instructions on how to restart your Versa 4 can be found here.
Additionally, please find below some tips to best charge Fitbit devices:
For charging purposes, your charging cable or your base station can be plugged into any USB power source, including but not limited to:
Best Answer07-08-2024 21:09
07-08-2024 21:09
Hi @pattyirene - that may not be the case. Mine has started taking anything up to an hour to go from 99% to 100%.
If it is a new watch it shouldn't take more than 15 minutes to reach maximum.
What you can try is restarting the watch and checking the cleaning and changing power source, perhaps use a PC for that.
However it is rarely worth charging to more than 97% as the time wasted charging buys you very little extra autonomy and you can't be wearing it if you are waiting for it to charge.
