05-15-2023
21:43
08:29
05-15-2023
21:43
08:29
my battery was at 58% and then it just turned off. I tried to put it on the charger and it doesn't respond to that either? Any suggestions
23:22
14:41
05-15-2023
23:22
14:41
Hi @Torific - unless the watch has developed a fault have a look here because it may not be charging.
How to check charge cable - Sense 2/ Versa 4 won't charge, won't start or blank screen
If it's just a screen fault it will still be syncing with the app. Worth checking.
Lastly try holding the button for a full 10 seconds till it vibrates and the logo appears if there is enough charge in it.
You can always chat via the Fitbit App, click profile photo, Help & support, Contact Customer support.
09:43
14:41
05-18-2023
09:43
14:41
Hi @Torific. Welcome to the Community Forums.
Thanks for the details regarding your Versa 4.
Please make sure that you've followed the steps provided in this article: Why isn't my Fitbit device's battery charging?
If the device is charging, but the screen is completely black, make sure that you've also completed the restart procedure described here: How do I restart my Fitbit device?
Thanks @Guy_ for your help in this matter.
Best Answer05-19-2023 12:34
05-19-2023 12:34
I have been having the same problems. Tried restarting and cleaning the charging terminals and still nothing. I can’t sync and can’t see my smart watch on the app. Last sync was May 5 and battery was at 58%.
Best Answer05-19-2023 12:53
05-23-2023 12:48
05-23-2023 12:48
For some reason a replacement went out to Dave below under my account. Not sure why. I do need a replacement but the one that is shipping is not mine and is going to a Dave and a different address. I need help
Best Answer05-23-2023 16:34
05-23-2023 16:34
@Guy_ , Thank you for your help .
@DaveB66 , A warm welcome to the Community! Thank you for your message. Did the help from Guy_ bring any improvement?
@Torific ,Thank you for getting back to us and bringing this to our attention. Our Team has been informed and you'll be receiving a message soon. Keep working with them to sort this out.
