Versa 4 won't sync after a factory reset
ANSWERED
I tried quick fix and it didn't work, I have now gone by to factory reset and nothing is working.  It keeps telling me to download the app from my phone but it won't let me.  Currently, I can't use the watch as there is no time on it.
1 BEST ANSWER
Accepted Solutions
Hi there, @MarieToronto. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa 4 stopped working after the factory reset. I understand your concern, I will do my best to help you with this!
Please note that the difficulty you are having to set up your Versa 4 usually happens when you perform a factory reset without first unpairing the watch. In order to solve this issue, I'd recommend trying the steps below:
  • Unpair your Fitbit device from your phone's Bluetooth and Fitbit app.
  • Unpair other Bluetooth devices that you may also have paired to your phone's Bluetooth settings.
  • Force quit the Fitbit app.
  • Turn off other Bluetooth connections when not in use. This can help to prevent connectivity issues or Bluetooth interference.
  • Turn on the Bluetooth on your phone.
  • Plug it into the charging cable and open the Fitbit app.
  • Set up your Fitbit device.
  • If there is no connection, restart your Fitbit device.
  • Once your Fitbit device is paired and syncing, please proceed to set up your other Bluetooth devices to your phone again.
With the steps above, what I want you to do is to pair your Versa 4 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Regarding the wrong time, please keep in mind that your Fitbit device may show an incorrect time if it hasn't synced or has been unpaired from your Fitbit account. Your Fitbit device uses the time of the device you're syncing with. Once you manage to connect your Versa 4, the time should be corrected.
1 REPLY 1
