01-13-2023
11:44
14:18
01-13-2023
11:44
14:18
Watch drops out of sync daily, takes 4 attempts to finally sync. I do not to Dont receive calls/textz to the fitbit
Hi there, @MoeFaco. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 4. @Guy_ Thanks for your help!
If you haven't done so yet, please see Why won't my Fitbit device sync?
Once you manage to sync your Versa 4, you should start receiving notifications. However, if they still won't come through, see Troubleshooting quick tips for iPhones
Hope that helps.
06:22
16:06
01-14-2023
06:22
16:06
@MoeFaco- for notifications, pull down the watch face to get top Quick Settings and make sure that neither Sleep nor Do nor disturb are enabled.
Often logout of the app and restarting the phone and watch again helps, making sure you are only using one phone and one watch, if there were / are others it can create problems.
Best AnswerNo luck. The watch has not auto sync since 28/1/23 and ive tried everything the Internet has recommended. I will return the watch, very unsatisfied it wont preform find my phone, show recent messages and show weather data. ☹️
Best AnswerNo luck, watch never auto syncs with phone and the watch struggles to manual sync too. It has not sync since 29/1/23 no features like find my phone or weather report work. Despite having wifi and mobile data at all times Unhappy with product will return.
