01-11-2023
07:01
11:14
AndreaFitbit
01-11-2023
07:01
11:14
AndreaFitbit
I needed to buy a new charge cord for my versa 4. I went to the Fitbit store to buy one, so bought the versa charge cord. It doesn’t fit at all! I guess the newer versas fit the charger for the charge Fitbit? But it would be nice if their online store, Fitbit would accurately label which charger works for which of their own devices.
Best Answer01-12-2023 04:08
01-12-2023 04:08
@Congomongo Welcome to the Fitbit community!
Here is the charging adapter you need for your Versa 4:
Fitbit Smartwatch Charging Cable
01-11-2023 08:42
01-11-2023 08:42
Hi @Congomongo I checked the Fitbit Store link and didn't find a Versa 4 charger, so I've asked a Fitbit Moderator to stop by to help you. Usually the item will state the specific Fitbit that it will charge. You probably got the one for Versa and Versa Lite unless you got the Versa 2 charger. Anyway, they should be able to help.
01-12-2023 04:08
01-12-2023 11:28
01-12-2023 11:28
Welcome to the Fitbit Community, @Congomongo. I'm sorry to hear about your Versa 4 charging cable experience.
I also checked the Fitbit store and original Versa charger wont match with your Versa 4. Versa 4 charging cable is the Fitbit Smartwatch charging cable, you can find the picture on @Talahthas post. You can return for refund your Versa charger and get the correct one.
Thank you for the heads up @Odyssey13.
Have an amazing day.
