I developed a pressure sore on my wrist area from wearing the Fitbit Versa 4. I guess it's a reaction to the plastic rubbing against my skin. I can put a bandage over it because it's below the area where my pulse is, but am just wondering if anyone else has experienced this and has some suggestions as to how to avoid this without interfering with the watch.
Hi @Carol571 - there can be a couple of reasons.
Firstly make sure the watch and strap are clean and wear on the other arm to allow recovery.
It can be an allergic reaction or simply from repetitive movements when there is moisture, dust or both, or even pinched skin.
If you get the same problem with a clean watch and strap on the other arm then it is most likely allergic and changing strap type may be an option.
For cleaning, it is important to follow the Fitbit guidelines.
Hi @Carol571 and welcome to the forums.
Thank you for your message! I'm sorry to hear that you are experiencing this situation with your watch.
As explained by @Guy_ (always appreciate your help) you might find helpful the following help article: How do I wear my Fitbit device?
Visit our Discussions board where you can share your experiences, meet people and create new topics.Si ma réponse vous a plu, merci de me féliciter. Si votre question a trouvé une réponse, acceptez la solution.If you liked my answer, give me a Kudo. If your question was answered, accept the solution.FR-EN-SPA.
