11-24-2019 18:53
11-24-2019 18:53
Hi team I have one plus 7 phone purchased from India and purchased versa 2 from USA. can just see know if there is a compatibility issue with this. If yes, then when we will expect a update on the compatible version. Dieing to wait for the update.
11-24-2019 22:35
11-24-2019 22:35
Hi @Darpan5715 The One Plus 7 is not on the Supported Devices List , so ifit is not working then it is possibly not going to. What are you having trouble doing? Have you set the fitbit up OK?
As far as updates regarding compatability, Fitbit doesnt say which phonesnit is working on. You just have to keep your eye on the list I linked .
Helen | Western Australia
Best Answer11-24-2019 23:35
11-24-2019 23:35
Try :
1) Disable the battery optimization for the Fitbit app
2) Lock Fitbit app in multitasking switcher
3) Restart your OnePlus device
