Dimensions of Versa in mm or inches?
ANSWERED
Hi
What are the dimension of the Versa case top to bottom, left to right, front to back in millimeters or inches?
The only info I have found is for the screen size which is .9478 in x .9478 in.
Thank you
Moderator edit: Title for clarity
1 BEST ANSWER
Accepted Solutions
Depth of the versa is 11mm.  By comparison the charge 2 is 13mm.  So the versa will sit more snugged into the wrist.  It’s also flat on the bottom so it won’t indent your wrist.  Just saying.
5 REPLIES 5
I've not received mine yet to measure but from discussions before launch I believe it's 39mm/1.5'' square. Not sure about the depth.
The case size is 1.55" X 1.55" X .44".
Not true. 35x35mm
On the website gadgetsandwearables.com it gives the watch dimensions as 39.35mm x 39.35mm x 11.24, which is about 1.55 in. X 1.55 x .45"
