04-19-2018 23:16 - last edited on 04-20-2018 04:40 by AlejandraFitbit
My Fitbit Versa was working and it just randomly turned off and will not turn back on. I have the Fitbit charging but there is no sign of it turning back on. Anyone know what is going on? This is a little frustrating since I have had it for a week.
07-10-2018 09:06
07-10-2018 09:06
I think I am going to do what you did and return mine at the local Target I got it from too many people are having the same issues. That’s really sad but that $250+ can be used for something else.
07-11-2018 20:17
07-11-2018 20:17
Fitbit Versa put on charge know won’t turn on , nothing totally dead, not happy at all only had for two weeks, brought it for my granddaughter, always had and used fitbits items but starting to wonder, can you help me in this case.
07-12-2018 17:31
07-12-2018 17:31
My Versa did the same but the restart trick worked like a charm.
07-13-2018 02:48
07-13-2018 02:48
How can you restart? The instructions say to go to settings on the Fitbit, but the Fitbit won't turn on. How did you restart and how often has this occurred?
07-13-2018 06:19
07-13-2018 06:19
07-14-2018 23:58
07-14-2018 23:58
Mine started doing this this morning. Less than a couple of months old, won't turn on, won't reset, charging does nothing.
07-15-2018 18:39 - edited 07-16-2018 16:17
Have had mine for about 24 hours. Noticed it wasn’t syncing anymore this afternoon so I restarted it. After the restart the Fitbit logo appeared momentarily but other than that the screen will not turn on. Tried the factory reset using the three buttons multiple times, no luck.
07-16-2018 03:41
07-16-2018 03:41
07-16-2018 03:52
07-16-2018 03:52
I received my Versa for Mother's Day, actually on 5/19/18. It was 100% charged yesterday morning. Today I woke up to my old school alarm clock and then realized the alarm didn't go off on the Versa. When I got out of bed, I noticed the black screen. It won't turn on by pushing any buttons, putting it on the charger does nothing. Not a happy person this morning.
Thankfully, I still have my Charge 2 and am using that today. What a waste of $200.
07-17-2018 17:56
07-17-2018 17:56
You're lucky it happened w/in 45 days if them shipping it to you. Unless you purchased an extended warranty, my advise to you is to get your money back! This has been going on for over a year. Mine died after 55 days. Started w/ not always syncing,fixed that then after a couple weeks it just died. All I can do now is send it back for an exchange. I asked if it would be a new replacement or refurbished...the tech couldn't tell me. Horrible!
07-17-2018 18:01
07-17-2018 18:01
I tried that to no avail. Good luck. I hope you have a better experience than I have had.
07-18-2018 02:08
07-18-2018 02:08
Unless you got extended warranty you only have 45 days to return for refund. This has been going on for over a year, doesn't look like they're fixing it anytime soon.
07-18-2018 02:10
07-18-2018 02:10
I tried the restart, that didn't work for me.
07-18-2018 02:13
07-18-2018 02:13
If you contact support after having it for more than 45 days, they will send you another one. It might be refurbished (they can't tell you whether you'll get new or not), otherwise you're just out 200+ bucks.
07-18-2018 02:15
07-18-2018 02:15
That is messed up! So disappointing. I'm warning everyone not to get a Versa!
07-18-2018 02:17
07-18-2018 02:17
Your story is similar to mine...I received mine for Mother's Day as well.
07-25-2018 04:32
07-25-2018 04:32
Thank you! This worked great.
07-25-2018 17:03 - last edited on 10-06-2021 05:00 by JuanJoFitbit
My Versa worked for about 3 weeks, and now it won't come on, despite being 85 percent charged. I've tried all the trouble shooting tips, restarting the Fibit, turning Blue tooth off and back on, trying to enter the number on the Versa display (no number comes up), etc. Fortunately, I bought a 3 year protection plan; should I call them and send it in? This is way too expensive of a device to be having problems like this and now I wish I never bought it! HELP!
Won't work for me despite repeated attempts. I very dim light comes on but that's IT
Moderator edit: merged reply
07-26-2018 03:12
07-26-2018 03:12
First I applaud your foresight to get the extended plan. You absolutely should send it in. Contact support and they'll tell you what you need to do. Good luck!
07-29-2018 04:22
07-29-2018 04:22
I am in my second versa. First unit I had since day one on April 16th and it died on june 17th around 7pm. After troubleshooting and charging on two different chargers still did not power. Contacted support sent picture of rear sensor windows having moisture in it and they started the exchange process. (Which I'd day was horrible). I returned it on the 18th of June and didn't get a replacement till July 6th. Anyway, 3 weeks later, seems I am on the same boat. Moisture in the sensors and won't turn on. Two different chargers, tried resetting a bunch of times and no dice. Have to contact support again to start a exchange. I will be selling the replacement as soon as I get it.
