Hello,
Would it be possible to have access to all the sleep_scores and temperature data relative to the sleep ?
E.g.:
overall_score,
composition_score,
revitalization_score,
restlessness
temperature_samples,
nightly_temperature,
baseline_relative_sample_sum,
baseline_relative_sample_sum_of_squares,
baseline_relative_nightly_standard_deviation,
baseline_relative_sample_standard_deviation
Thank you 🙂
Hi @Danner1995
Sleep score is not available through the Web API. You can receive a sleep efficiency score, though it is different. Skin Temperature is recorded while the user is sleeping and can be retrieved using the Get Skin Temperature endpoint. You can check the endpoints to see what information is returned.
