07-30-2020 13:44
07-30-2020 13:44
Hey everybody!
I would like to use the new userRevokedAccess subscription, but am getting "insufficient permissions" even though the docs say this:
This is reproducible in the Fitbit Web API tester at https://dev.fitbit.com/build/reference/web-api/explore/#/Subscriptions/addSubscriptions if you choose a limited set of scope permissions when performing the OAuth authorization. For instance, try choosing "activity", "heartrate", and "profile".
Specifically, this POST:
curl -X POST "https://api.fitbit.com/1/user/-/userRevokedAccess/apiSubscriptions/320.json" -H "accept: application/json" -H "authorization: Bearer eyJhbGciOiJIUzI1NiJ9.eyJhdWQiOiIyMjdHNUwiLCJzdWIiOiI4TkNSMksiLCJpc3MiOiJGaXRiaXQiLCJ0eXAiOiJhY2Nlc3NfdG9rZW4iLCJzY29wZXMiOiJ3aHIgd3BybyB3YWN0IiwiZXhwIjoxNTk2MjIwMjIxLCJpYXQiOjE1OTYxMzM4MjF9.bUaq3LDrPDUj8s1HfM8OsaMJCmmp4u6asK5yKOJn1yQ" -d ""
Receives this 403 response:
{ "errors": [ { "errorType": "insufficient_scope", "message": "This application does not have permission to access nutrition, settings, sleep, weight data. Visit https://dev.fitbit.com/docs/oauth2 for more information on the Fitbit Web API authorization process." } ], "success": false }
Just wondering if there is a workaround or an imminent fix? (We don't want to ask the user for all permissions because the sign up rate will decrease.)
Best Answer08-07-2020 08:47
08-07-2020 08:47
Hey everybody. This issue got double-posted. The problem has been fixed and marked as resolved here: https://community.fitbit.com/t5/Web-API-Development/Attempting-to-subscribe-to-userRevokedAccess-res...
Best Answer07-31-2020 17:54
07-31-2020 17:54
Hi @JohnAtPaceline,
Thanks for reporting this! I too was able to reproduce this issue. I'll file a ticket to the team and have this corrected as soon as possible.
Thanks!
Best Answer08-05-2020 12:10
08-05-2020 12:10
I'm seeing nearly identical behaviour from our integration after trying to subscribe to userRevokedAccess notifications. The error we see is:
This application does not have permission to access nutrition, settings, sleep data.
We get permission for 'activity heartrate profile weight' scopes in our authentication flow.
Best Answer08-05-2020 12:28
08-05-2020 12:28
Thank you, @EthanChid . We are working on a fix for the userRevokedAccess collection.
08-07-2020 08:47
08-07-2020 08:47
Best Answer08-10-2020 11:10
08-10-2020 11:10
Yes, it's working for me now. Thanks for the quick response
