Hello Fitbit Team,
I am working as one of Validic API Support Team and we have integrated with your API. We have been using the old process of applying your App credentials which is Oauth 1.0. I have noticed that on April 2016 we are then required to updated our existing oAuth 1.0 applications to Oauth 2.0. Our developers are currently working on this adjustment.
With the request of our new clients, I tried applying for new sets of your App credentials by using the old process (Oauth 1.0) as this is still what we are using. Unfortunately, I get the following error below:
https://www.dropbox.com/s/jm6qf89sru09g8s/Screenshot%202015-11-10%2004.38.40.png?dl=0
Does this mean that we have to apply new credentials as Oauth 2.0 in order for us to proceed?
Hoping for your assistance and guidance on this.
Thanks in advance!
Kind regards,
Mic Raz
Team Member, Validic
Hi @Hacim, this is a bug in the registration page that we are fixing. You just need to enter a callback URI to register the app. You can change it later. You can even use http://localhost/ as a placeholder if you need.
Hi Jeremiah,
Thank you so much for the usual assistance and guidance.
Kind regards,
Mic
