Here is my request
curl -X POST -i -H 'Authorization: OAuth oauth_consumer_key="b**9f1", oauth_nonce="e390ca4db", oauth_signature="E7Bus8hCIV6fRHvIC7s5K0CMOao%3D\
", oauth_signature_method="HMAC-SHA1", oauth_timestamp="1433131852", oauth_token="50**9ae6", oauth_version="1.0"' "https://api.fitbit.com/1/user/3**2/de\
vices/tracker/33**511/alarms.json?time=12%3A10%2B8%3A00&enabled=true&recurring=false&weekDays=MONDAY"
HTTP/1.1 500 Internal Server Error
Server: nginx
X-UA-Compatible: IE=edge,chrome=1
Expires: Thu, 01 Jan 1970 00:00:00 GMT
Cache-control: no-cache, must-revalidate
Pragma: no-cache
Fitbit-Rate-Limit-Limit: 150
Fitbit-Rate-Limit-Remaining: 141
Fitbit-Rate-Limit-Reset: 2881
Content-Language: en
Content-Length: 196
Date: Mon, 01 Jun 2015 04:11:59 GMT
{"errors":[{"errorType":"request","fieldName":"500","message":"An error occurred with the Fitbit API while processing the request. Please contact api@fitbit.com for assistance."}\
],"success":false}bash-3.2$
bash-3.2$
Best AnswerI get this error too. Deleting an alarm works fine but not creating one. Here is my request (I removed my token and tracker id for privacy reasons) and result:
curl -X POST -i -H "Authorization: Bearer [my token]" -d "enabled=true" -d "recurring=true" -d "time=23:00+02:00" -d "weekDays=MONDAY" https://api.fitbit.com/1/user/-/devices/tracker/[my tracker id]/alarms.json
Date: Tue, 04 Apr 2017 21:03:56 GMT
Content-Type: text/plain
Content-Length: 215
Connection: keep-alive
Cache-control: no-cache, private
Fitbit-Rate-Limit-Remaining: 150
Fitbit-Rate-Limit-Reset: 3364
X-Frame-Options: SAMEORIGIN
Server: cloudflare-nginx
CF-RAY: 34a737997fb13c35-CDG
{"errors":[{"errorType":"request","fieldName":"500","message":"An error occurred with the Fitbit Web API while processing the request. Error id: 8D655804:7B14_A92D826B:01BB_58E40A3C_C7D17A17:1800"}],"success":false}
@hujaek I used curl and was able to successfully set an alarm:
curl -X POST --header 'Content-Type: application/json' --header 'Accept: application/json' --header 'Authorization: Bearer {token}' 'https://api.fitbit.com/1/user/-/devices/tracker/{trackerid}/alarms.json?time=12%3A00-08%3A00&enabled=false&recurring=false&weekDays=MONDAY'
