Endpoint not successfully verified
Setting up FitBit auto-syncing.
We do see the 2 requests in the IIS logs, but the endpoint is still not being verified. We use a proxy server and redirect to the server we want, which is not externally accessible.
Both are GET request and one is a 204 and the other is a 404. The verification code for the 204 matches up with what is on the FitBit site.
7 REPLIES 7
@Get2Requests Are you replying back to the GET requests with the appropriate 204 and 404 responses?
Andrew | Community Moderator, Fitbit
What motivates you?
Yes, it is responding with a 204 and 404
Andrew, We are seeing the same issue as well, how can we proceed to find the issue? I can provider more information if it is needed.
@JeremiahFitbit
Could we get a response to this issue?
@Get2Requests @jlin Send me your subscriber endpoint url via PM.
What motivates you?
Greetings - we are experiencing this issue at Houston Methodist. I would appreciate learning about any new findings. Thanks!
We still can't fix the issue (Get2Requests has sent you the endpoint, we are together). May I ask if we can get the same kind of feedback as we have for notifications so that we know where is the problem?
