08-15-2021 13:06
08-15-2021 13:06
I am following the Authorization Code Grant Flow with PKCE. I've checked over all of my steps several times, and as I've mentioned as a response to another post, I am very sure that I'm hashing and encoding the code verifier correctly : When I tried hardcoding the code_verifier as the example '01234567890123456789012345678901234567890123456789' I get the correct code challenge as shown in the example (which I checked by printing it out). And I also receive the following error from fitbit: 'Authorization code verifier invalid: 01234567890123456789012345678901234567890123456789'. I'm not sure what I'm doing incorrectly here, and I've been struggling with this issue for over a week now. So please please let me know if you have any advice or would know what things I should also triple check to make sure I'm calling the /oauth2/token end point correctly. Thank you so much for your help, in advance :)!
08-20-2021 12:30
08-22-2021 17:03
08-22-2021 17:03
Hi @JohnFitbit, , I'm unable to private message you. I do not see the option on your profile page. Is there another way to send the Client ID to you?
08-24-2021
20:20
15:53
JohnFitbit
08-24-2021
20:20
15:53
JohnFitbit
I am following the Authorization Code Grant Flow, i just can not open this Link for code:
{REDACTED}
08-26-2021 16:15
08-26-2021 16:15
@ssshar It looks like you had PM disabled in your settings. We temporarily removed it so you can send me the info. Click my name and you should see a "Send Message" button in the following page.
@xiaofang Are you experiencing the same issue? I also removed your authorization url as it displayed your Client ID to the public. If you are experiencing this issue as well, please PM me your Client ID also.
12-01-2021 11:05
12-01-2021 11:05
Hi @JohnFitbit I'm not sure if this is the appropriate way to ask this, but I'm also having the same error as the OP on this post. I confirmed that my encoding was producing the same result as the example in https://dev.fitbit.com/build/reference/web-api/developer-guide/authorization/. I also confirmed that I don't have a typo in the code_challenge_method or any of the other problems that others seem to have had.
I would love any input you could give. Thank you.
