08-09-2016 05:02
08-09-2016 05:02
Hi All
I am not developing/maintaining an app, all I do is grab data from several fitbits whose credentials and data I am in charge of and store it in a local database. The way I did it in OAuth 1.a was that I had all the tokens and secrets hard coded in an a array (token_array/secrets_array) and straightforward created the API credentials and then grabed the data:
for i=...
API ResourceCredentials resourceCredentials = new APIResourceCredentials(userId[i],token_array[i],secrets_array[i])
...grab data and store in locel DB,
next
is this still possible with the OAuth 2.0 and if yes what do I have to change in my code? As you might have guessed, I am not a software engineer and my understanding of the topic is quite limited.
Any help is appreciated
Best Answer08-18-2016 17:00
08-18-2016 17:00
First, you need to upgrade each person's OAuth 1.0a access token and access token secret to an OAuth 2.0 access token and refresh token. Instructions for that are at https://dev.fitbit.com/docs/oauth2/#migrating-from-oauth-1-0a .
Then, to make requests, you can do what you are currently doing. With OAuth 2.0, you only need the person's access token to make an API request. The "Authorization" header is a value of "Bearer " and the OAuth 2.0 access token. An example of an OAuth 2.0 API request is at https://dev.fitbit.com/docs/oauth2/#making-requests .
Unlike OAuth 1.0a access tokens, OAuth 2.0 access tokens expire regularly. Your app has to refresh them. This process is described at https://dev.fitbit.com/docs/oauth2/#refreshing-tokens .
Best Answer10-25-2016 02:41
10-25-2016 02:41
Hi Jeremiah
Thx for your reply. I found this similar post: https://community.fitbit.com/t5/Web-API/Lifetime-Access-Tokens-for-Command-Line-Tools/m-p/1141477/hi...
and followed the steps.
Authorization works and I get the code
But when I try to do the "access token request" it always says:
this request must use the HTTPS protocol
Any idea why this happens?
Best
Robin
Best Answer10-25-2016 11:19
10-25-2016 11:19
@RobinKu You need to use https:// instead of http://
11-16-2016 01:38 - edited 11-16-2016 01:38
I do use https and I still get this error message!
Best Answer11-16-2016 11:13
11-16-2016 11:13
@sdfe Can you show me the request you're making?
Best Answer09-04-2017 02:55 - edited 09-04-2017 02:57
I assume it is too late for @RobinKun but for people that are facing this error message, I just come to get it and it has nothing to do with HTTPS.
In my case it is due to a double slash in the URL.
This request works:
https://api.fitbit.com/1/user/-/body/log/weight/date/2017-08-15/2017-09-04.json
This one returns the this request must use the HTTPS protocol error message:
https://api.fitbit.com/1/user/-/body/log/weight//date/2017-08-15/2017-09-04.json
It occurs wherever the doubled slash is:
https://api.fitbit.com/1/user//-/body/log/weight/date/2017-08-15/2017-09-04.json
It would be nice if that could be fixed, it can conduct to a massive loss of time for the Fitbit's API integrators.
Hope it will help!
