02-06-2025 14:43 - edited 02-06-2025 14:49
https://www.fitbit.com/oauth2/authorize?response_type=code&client_id=#&redirect_uri=#%2F&scope=activity%20heartrate%20settings%20sleep%20oxygen_saturation%20profile%20respiratory_rate&code_challenge=#&code_challenge_method=S256
Here is my URL with 7 scopes added. When I include only 6 scopes, it works fine, but with 7 scopes, one of them gets skipped.
I want to know if Fitbit has a limitation on the number of scopes or if there is a bug on my end.
02-07-2025 12:06
02-07-2025 12:06
Hi @usamaa
You can add all of the scopes in your authorization URL. I'll reach out to you directly to get some more information from you.
Best Answer03-10-2025 15:48
03-10-2025 15:48
I'm still facing the same issue. Can you please help me?
When I select the scopes manually, the last one i select is ignored.
For example ==> if i click on profile's checkbox in the last the it gets ignored.
and if is click on allow all then the settings gets ignored
Here is the URL I am using:
https://www.fitbit.com/oauth2/authorize?response_type=code&client_id=&redirect_uri=https%3A%2F%2Ffit...
Best Answer03-12-2025 06:18
03-12-2025 06:18
What do you mean by the last checkbox gets ignored?
Best Answer03-12-2025 13:22
03-12-2025 13:22
For example if i select sleep in the last from this list in the screenshot then it gets skipped
Best Answer03-13-2025 07:16
03-13-2025 07:16
How do you know it gets skipped? When you use the /oauth2/token endpoint to exchange the authorization code for the access token and refresh token, do you see all the scopes listed in the response. For example
If you're getting an error when calling the endpoint for sleep, what is the syntax you are calling and the error message received?
