10-16-2017 10:42
10-16-2017 10:42
I would like to change the daily step count goal for a user from 10,000 steps to 20,000.
I successfully retrieved data on all activity goals from the endpoint (/1/user/-/activities/goals/daily.json), but when I try to POST a change to the "steps" goal using the same endpoint, the data on the server does not change (it still says goal = 10000).
The documentation provides no clues as to what might be happening here. How can I change the goals for the day?
I am using fetch in javascript to get the goal json object:
var goalPostUrl = 'https://api.fitbit.com/1/user/-/activities/goals/daily.json';
fetch( goalPostUrl, { headers: new Headers({ 'Authorization': 'Bearer ' + fitbitToken }), mode: 'cors', method: 'GET' }).then(processResponse) //returns response.json() .then(alterGoal) var alterGoal = function(goal){ goal["goals"]["steps"] = 20000; fetch( goalPostUrl, { headers: new Headers({ 'Authorization': 'Bearer ' + fitbitToken }), mode: 'cors', method: 'POST', body: JSON.stringify(goal) }).then(processResponse).then(function(postResponse){console.log(JSON.stringify(postResponse));})
Thank you.
10-18-2017 14:38
10-18-2017 14:38
I figured out the issue, and I will post it so that it will be helpful to others. This is not very well-documented and perhaps non-intuitive. I think my confusion was due to a combination of Fitbit + Javascript/Fetch ambiguity.
First, in my original attempt, I was trying to POST data using the "body" parameter. This is what has been recommended elsewhere on StackOverflow for POST requests. Applied to Fitbit, if the JSON was well-formed, the POST request succeeded. There was no error generated, simply nothing updated. (see image for detailed parameters)
However, the Fitbit API apparently only takes *parameters* to a POST request, not data sent as the body of a request. (in cURL, this is represented as "--data". In Fetch, this means actually manually appending data to the URL: https://github.com/github/fetch/issues/256)
So, to solve this problem I changed the actual URL (see below):
fetch( 'https://api.fitbit.com/1/user/-/activities/goals/daily.json?steps=25000', { method: 'POST', headers: new Headers({ 'Authorization': 'Bearer ' + fbTok, }), mode: 'cors', } ).then(processResponse) .then(function(data){ console.log('Request succeeded with response', data);}) .catch(function(error){ console.log(error.message);});
And it works!
10-17-2017 22:57
10-17-2017 22:57
@jaztech, I'm not familiar with javascript library you're using to make POST request. Are you able to reproduce the same behavior with CURL?
Can you please verify that you see the same behavior when you do something like:
curl -vvv -X POST -H "Authorization: Bearer yourToken" -d "steps=20000" https://api.fitbit.com/1/user/-/activities/goals/daily.json
What the response are you seeing when you execute this curl above?
10-18-2017 10:23
10-18-2017 10:23
Hi @IoanbsuFitbit I was using the javascript Fetch library to make the original request.
I tried to make the cURL request you suggested, but I do not get any response back at all. (I copied my access token from the end of the URL and pasted it into the line).
10-18-2017 10:53
10-18-2017 10:53
As an update, I got the cURL request to work. I'm not that familiar with it, so there were some improperly formatted parts. The response from the server is the JSON object with "steps" now updated to 20000.
10-18-2017 12:22
10-18-2017 12:22
@jaztech does you last response mean that you found out what was wrong in your original approach using JS library?
The
man curl
will display pretty comprehensive documentation about curl syntax. But if you have further questions about how to make and api request, please let us know.
The reason I like curl is because it allows you to make request by clearly specifying all the attributes of http(s) request and does not do any hidden-by-framework magic unlike other frameworks often do.
10-18-2017 12:52
10-18-2017 12:52
Hi @IoanbsuFitbit, no I have not resolved the original issue.
The challenge is that, using javascript, the request seems to go through. I get a response from the server similar to how I got back from the cURL request. However, in the response to the javascript version, the server never actually updates the step value.
So, when I submit a CURL, it is 200, with json response reflecting the POSTed changes.
When I submit the same request using javascript, it is also 200, but the json response (nor any subsequent GET requests) does *not* reflect the POSTed changes.
10-18-2017 13:18
10-18-2017 13:18
I'm not a PRO in reading how FETCH JS library works, but I see that in your first request you make GET request(method: 'GET') and passing to it
goalPostUrl
. which seems inconsistent to me. Is it that you just not naming the URL correctly, or you wanted to make POST request instead of GET?
Also, the way you pass steps=20000 parameter is kind-a weird. If you using Chrome browser you should be able to see what request actually this JS library have generates to you in Network tab in developer tools for Chrome. Can you please verify that the POST request in this network tab looks correct to you?
10-18-2017 13:29
10-18-2017 13:29
After trying cURL and Fetch requests with a bunch of other endpoints, I think one concrete problem that I'm having is that I do not know what data the Fitbit server expects from a JSON post. cURL requests, as I understand it, append data to the URL (i.e. baseurl?data=value)
The documentation assumes this kind of information passing rather than sending a stringified JSON object. If I send a JSON object instead, can the Fitbit server handle this? Or do I need to find a way to send url appended data?
10-18-2017 13:46
10-18-2017 13:46
Fitbit api endpoints do not expect the request to be json-formatted.
The *.json at the end of the endpoint defines the response format but definitely not the request format. The request parameters should be specified they way they are specified in regular post requests.
10-18-2017 14:38
10-18-2017 14:38
And it works!
