02-08-2023 02:44
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
02-08-2023 02:44
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Hello,
I try to access to my personal temperature but I get the "
curl --location --request POST 'https://api.fitbit.com/oauth2/token' \
--header 'Authorization: Basic MYTOKEN' \
--header 'Content-Type: application/x-www-form-urlencoded' \
--header 'Cookie: JSESSIONID=E66137AAF7B39115F77E0A7A8810A95B.fitbit1; fct=afbca93311fc4c0bbc8279d5c4898ddc' \
--data-urlencode 'grant_type=client_credentials'
"access_token": "MYTOKEN",
"expires_in": 28800,
"scope": "",
"token_type": "Bearer"
Scope is empty, is it why I can't query my temp ? How can I change that?
Here's the request I make :
curl --location --request GET 'https://api.fitbit.com/1/user/2TP6GS/temp/skin/date/MYDATE.json' \
--header 'Authorization: Bearer MYTOKEN' \
Thanks
Accepted Solutions
02-08-2023 11:34
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
02-08-2023 11:34
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Who Voted for this post?
Hi @poupi
Client Credentials authorization flow is not supported by Fitbit to pull data through the Web API. See https://dev.fitbit.com/build/reference/web-api/developer-guide/authorization/#Other-Supported-Author...
You'll need to use the authorization code grant flow or implicit grant flow. The scopes are listed in the authorization URL. I would recommended checking out this section of the documentation for instructions on authorizing a user; https://dev.fitbit.com/build/reference/web-api/developer-guide/authorization/#Authorization-Code-Gra.... If you're pulling only your data, you can opt out of the PKCE pieces.
Let me know if you have further questions.
Best,
Gordon
Senior Technical Solutions Consultant
Fitbit Partner Engineering & Web API Support | Google
02-08-2023 11:34
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
02-08-2023 11:34
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Hi @poupi
Best,
Gordon
