06-20-2016 22:03
06-20-2016 22:03
Hi all,
Having some issues with insufficient permissions when trying to get info from other accounts that aren't the account the app is hosted on. For example, when I try to do a get request to https://api.fitbit.com/1/user/[user-id]/activities/date/[date].json using an access token from my account (the account that the app was created on), I'll get data back. If I try using my friend's account, I get back the error below:
"errors": [
"errorType": "insufficient_permissions",
"message": "API client is not authorized by the resource owner to access the resource requested. Visit https://dev.fitbit.com/docs/oauth2 for more information on the Fitbit Web API authorization process."
"success": false
The authorization header follows the form 'Bearer {insert access token here}'. Any idea what might be going on? Thank you!
Best Answer06-20-2016 22:11
06-20-2016 22:11
Your friend will need to authorize your app. Your app will need to use the access token for your friend in order for your app to access their data.
Best Answer06-20-2016 22:21 - edited 06-20-2016 22:41
When they first log in, I successfully get their access token and the app shows up as authorized in the Application tab of their settings. Even with all of this, I still get the error that I have insufficient permissions.
