06-17-2022 05:30
06-17-2022 05:30
I try to extract activity time series data by date range. However, there is a limit on how far back I can go in number of days and this differs from individual to individual. For some subjects I can extract 693 days of data, for other subjects it differs and I can't find the exact limit. Is this specified somewhere?
06-22-2022 08:45
06-22-2022 08:45
I know with some of the activity resources, you can only query a certain amount of data which is approximately 1M bytes. This would explain why you can query X amount of days for one user by not the next. My recommendation is to reduce your interval to 3 - 6 months. This should prevent you from hitting any type of response size restriction.
06-17-2022 10:52
06-17-2022 10:52
Hi @KULKver
I will clarify this the documentation. In the meantime, which resource are you querying with the activity time series endpoint? Some of the resource have different restrictions.
Gordon
06-20-2022 05:29
06-20-2022 05:29
I'm querying steps, distance, calories, etc., almost everything that can be queried. For all of these activities, I provide a begin and end date. And often the time period between begin and end date is too large causing the error that too many data points are being requested.
06-22-2022 08:45
06-22-2022 08:45
06-22-2022 09:03
06-22-2022 09:03
That's good to know, thanks!
