12-16-2014 02:54
12-16-2014 02:54
Hi All,
I am using ohmyauth library for fitbit auth. It is working fine but its giving only one date data and I want to access full data for aunthiticate user.
Below is my code please review and guid me how can I access import all data ?
use ohmy\Auth1;
# start a session to save oauth data in-between redirects
# initialize 3-legged oauth
$fitbit = Auth1::init(3)
->set('key', 'b61dd455b43744248fe109cdf2b8d814')
->set('secret', '1bca137f8f444158958c0403106036c0')
->set('callback', 'https://fitfocus.me/fitbit.php')
# oauth
->request('https://api.fitbit.com/oauth/request_token')
->authorize('https://api.fitbit.com/oauth/authorize')
->access('https://api.fitbit.com/oauth/access_token')
# save user id
->finally(function($data) use(&$user_id) {
$user_id = $data['encoded_user_id'];
# destroy session
// ->finally(session_destroy);
# test GET call
$fitbit->GET("https://api.fitbit.com/1/user/$user_id/profile.json")
->then(function($response) {
$_SESSION['profile~'] = json_encode($response->json());
$udata = $data = array();
$udata['user_id'] = $data['user_id'] = $user_info['id'];
$udata['api_type'] = $data['api_type'] = 'fitbit';
$udata['profile_data'] = $_SESSION['profile~'];
$udata['created'] = $data['created'] = date('Y-m-d H:i:s');
$fitbit->GET("https://api.fitbit.com/1/user/$user_id/activities/date/2014-03-25.json")
$_SESSION['data~'] = json_encode($response->json());
Its giving data of '2014-03-25' and I need all data in user account.
Thanks
12-16-2014 08:27
12-16-2014 08:27
Hello,
It gives you data for 2014-03-25 because you query data for that date with query: "https://api.fitbit.com/1/user/$user_id/activities/
You can do all sort of queries to return the data that you want for period of times that you want.
More information you can find here:
https://wiki.fitbit.com/display/API/Fitbit+API
We currently do not allow to import/export all user's data.so you'll have to make several queries to get the data that you want.
Best Answer12-16-2014 08:27
12-16-2014 08:27
Hello,
