Notification Subscriptions using https result in SSLException
ANSWERED
An http subscription url was working fine responding in 204.
After modifying the subscriber notification url to use https it began reporting 'SSLException'
I can't seem to locate any information on what the problem may be.
undefined
SSL is terminated using haproxy and the oauth process seems to be happy using https through and through.
This seems to be isolated to the notfication calls.
2 BEST ANSWERS
Accepted Solutions
Hello,
We support TLS(v 1.0)/SSL protocol for the subscriber endpoints. Please, note that we are not supporting self-signed certificates. We support only HTTPS connections to port 443. TLS+SNI is not supported at this time. Note that TLS v. 1.1. and 1.2 are not supported at this point.
Please check that you code satisfy all these requirements.
Ivan Bahdanau
Senior Software Developer at Fitbit
Thank you!
SNI is definately in effect here.
I will rework things to match what is supported.
2 REPLIES 2
Hello,
Ivan Bahdanau
Thank you!
