Your app should accomodate 1,024 bytes per token.
@m4olivei You can select the lifetime of the access token.
Authorization Code Grant Flow: 1 hour or 8 hours (defaults to 8 hours)
Implicit Grant Flow: 1 day / 1 week / 30 day / 1 year (defaults to 1 day)
Refresh tokens do not expire until they've been used, or if the user goes through the authorization process again.
Best AnswerThanks, but we're asking about the character length of the token. Is there a defined length of token, or can it vary. Is it different for the access_token and refresh_token?
