07-03-2018 01:07 - edited 07-03-2018 02:31
Hello,
Why it is required to put a client_secret in a request header when using PKCE? I thought the whole point of PKCE is NOT to use client_secret?
https://dev.fitbit.com/build/reference/web-api/oauth2/
Authorization Header
The Authorization header must be set to Basic followed by a space, then the Base64 encoded string of your application's client id and secret concatenated with a colon. For example, the Base64 encoded string, Y2xpZW50X2lkOmNsaWVudCBzZWNyZXQ=, is decoded as "client_id:client secret".
POST https://api.fitbit.com/oauth2/token Authorization: Basic Y2xpZW50X2lkOmNsaWVudCBzZWNyZXQ= Content-Type: application/x-www-form-urlencoded client_id=22942C&grant_type=authorization_code&redirect_uri=http%3A%2F%2Fexample.com%2Ffitbit_auth&code=1234567890&code_verifier=dBjftJeZ4CVP-mB92K27uhbUJU1p1r_wW1gFWFOEjXk
07-03-2018 10:46
07-03-2018 10:46
Hi @remiwaw. Great question!
PKCE doesn’t replace the Authorization Code Grant Flow. PKCE is an extension to the authorization flow which provides added security when verifying and authorizing the client / server connection. You’ll still follow the Authorization Code Grant Flow process to obtain the authorization code and access token. Authorization Code Grant Flow does require using the client_secret as you pointed out.
When using the parameters introduced in the PKCE standard, the additional verification step will be followed within the existing authorization request to obtain the access token.
07-03-2018 10:46
07-03-2018 10:46
07-10-2018 05:36
07-10-2018 05:36
According to Oauth documentation, when used in native apps client-secret shouldn't be hardcoded within apps:
Secrets that are statically included as part of an app distributed to multiple users should not be treated as confidential secrets, as one user may inspect their copy and learn the shared secret. For this reason, and those stated in Section 5.3.1 of [RFC6819], it is NOT RECOMMENDED for authorization servers to require client authentication of public native apps clients using a shared secret, as this serves little value beyond client identification which is already provided by the "client_id" request parameter.
https://tools.ietf.org/html/draft-ietf-oauth-native-apps-12#section-8.5
As you mentioned the server still requires this code for authentication:
So how we can safely store client-secret within app?
07-12-2018 17:28
07-12-2018 17:28
With a couple of searches, I found a couple of web pages that explain how to store your secret. Here are some links you can review. I'm sure there are other ideas for you to consider
https://www.oauth.com/oauth2-servers/client-registration/client-id-secret/
https://stackoverflow.com/questions/28609526/store-client-secret-securely
I would like to highlight one important comment in the RFC (https://tools.ietf.org/html/rfc8252#section-8.5😞
Authorization servers that still require a statically included shared secret
for native app clients MUST treat the client as a public client (as
defined by Section 2.1 of OAuth 2.0 [RFC6749]), and not accept the secret
as proof of the client's identity. Without additional measures, such
clients are subject to client impersonation (see Section 8.6).
09-22-2020 07:03
09-22-2020 07:03
@Gordon-C we are currently looking at reviewing our use of secrets and certificates throughout our app. The fact we have our client_secret in the native app is a concern. We are currently using Authorization Code Grant Flow.
The way I read your replies you are saying that even with PKCE you still need to send the "client_secret". Am I understanding you correctly? I ask this because we just tried using PKCE with Postman against the Fitbit API and we did not need to send a client_secret.
Thanks
10-01-2020 10:19
10-01-2020 10:19
Hi @MunkiiYebee
Yes. With PKCE you will still need to use your client secret in the Basic token to initiate the authorization flow. I'm curious how you were able to use PKCE within Postman and not need a client_secret. Would you be able to record a video and PM it to me?
10-07-2020 07:44
10-07-2020 07:44
I'll send the video over now
10-16-2020 09:48
10-16-2020 09:48
A correction to my previous reply. PKCE does not require using the client secret to initiate the authorization flow. Instead, the code_challenge and code_verifier will be used to authenticate the application with Fitbit and define user consent with application. Your application type should be set to "client" instead of "server".
We will clarify this information in the documentation.
11-13-2020 08:53 - edited 11-13-2020 10:07
Hi Gordon,
In order to exchange the authorization code receiving using the PKCE flow into a token, I need to make an Access Token Request, which requires the setting of an `Authorization` header composed of a Base64 encoded string of my application's client id and secret concatenated with a colon.
This means I need to embed the client secret in my app, which is not what I want to do. I thought the whole point of the PKCE flow was to provide a way for apps to authenticate without embedding a secret in the app.
Am I misunderstanding something?
Damian
UPDATE:
Despite the documentation indicating it is required, the authorization header is not required when translating the code to a token during PKCE
11-24-2020 05:27
11-24-2020 05:27
Hi damianmehers,
I have the same opinion as you, and I solved the same issue with your UPDATE comment.
Thank you!
And I think definitely this behavior(of not needing authorization headers) should be written in the document to assure that client_secret is not needed at all when using PKCE.
