Hello,
My Subscription Endpoint is like;
http://myapplication.com/SubscriptionHandler.ashx?provider=Fitbit
For verification your servers are hitting endpoint attaching ?verify=123 regardless there is already a querystring parameter exists or not. So it is hitting my server like;
http://myapplication.com/SubscriptionHandler.ashx?provider=Fitbit?verify=123
Can you please fix the issue there if there is already parameter like ?param=1 hit appending &verify=123 ?
Best AnswerThe issue has been resolved. Thanks for reporting.
Hi reyou,
You're right. We'll look into a fix for this case. In the meantime, you can get around this issue by removing the ?provider query string.
Best AnswerThanks for your reply.
I need that query string because I filter out providers other than FitBit such as other Health Related Vendors.
I am using same endpoint for different vendors.
