05-13-2016 07:11
05-13-2016 07:11
Hi guys,
I am trying to figure out how to use the api of fitbit with xcode in swift. Unfortunately I can't figure out what steps I have to do to achieve this. The first thing is the registration of the app. They are asking for a callback url, I've never used a callback url before with any api. (weather api, pokemon api etc..)
Is there anyone who can make a step by step help/tutorial for me implicit for IOS in xcode with swift?
I would really appriacte this because I stuck now.. 😞
Anyway, for any question or for more information don't hesitate to contact me.
Kind Regards,
Kevin.
05-13-2016 08:59
05-13-2016 08:59
Best Answer05-19-2016 01:39
05-19-2016 01:39
Hi,
Thank you but this is objective c and not in swift mate.
I hope anyone else can help me out with setting up the fitbit api for xcode in the language swift!
Kind Regards,
Best Answer05-19-2016 13:25 - edited 01-14-2017 16:26
kevinvugts wrote:Thank you but this is objective c and not in swift mate.
@kevinvugts It is in Swift.
Go here and cmd+f "Fitbit2":
{removed link - no longer exists}
Also might want to check this out:
http://stackoverflow.com/questions/17540357/call-back-url-for-ios-app
Our API docs is a good resource as well. Ultimately, this requires a bit of research on your end.
Best Answer01-14-2017 16:08
01-14-2017 16:08
THe Link is broken and I need the name help as kevinvugts
Best Answer01-14-2017 16:25
01-14-2017 16:25
@SunsetRunner Looks like it was removed. You can still check out the project:
Best Answer01-14-2017 16:28
01-14-2017 16:28
@AndrewFitbit wrote:@SunsetRunner Looks like it was removed. You can still check out the project:
https://github.com/OAuthSwift/OAuthSwift
THX ![]()
Best Answer01-22-2017 19:03
01-22-2017 19:03
Hi, I wrote one for myself based on several Alamofire tutorial. You can check it out here: https://github.com/caroline6927/QuickStartApp/blob/master/QuickStartApp/FitbitAPiHelper.swift
01-24-2017 07:54
01-24-2017 07:54
@caroline6927 Thanks for sharing! 🙂
Best Answer06-17-2018 11:06
06-17-2018 11:06
hi,
I am having the same issue....if you know the solution can u tell me please.
thanks & regards
Best Answer06-25-2018 12:16
06-25-2018 12:16
Hi @bunnyyy. Do you have questions about the callback URL or the sample code?
Best Answer06-25-2018 23:20
06-25-2018 23:20
