06-19-2017 10:25
06-19-2017 10:25
Hi,
I've been trying to adjust the stride length on my fitbit zip and whenever I enter changes to my desktop dashboard it doesn't get saved. I've changed my stride length on my online dashboard to 30.6 inches and it's saved on there, but every time I change it on my desktop dashboard to 30.6 it reverts back to 30.5 inches. My zip is synced to the desktop dashboard because when I walk for exactly 1 mile (on mile marked trails) it still shows I'm always exactly 0.04 mile short.
Scott F
Best Answer06-25-2017 14:25
06-25-2017 14:25
Thanks for stopping by @forgerelli! That sounds kind of odd.
I suggest updating your stride length from your online Dashboard. Then log out and log back in again; your info should be updated.
Hope this helps, keep me posted!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
