06-23-2017 09:07
06-23-2017 09:07
trying to getzip fit to sync and keep getting message that it is unable to communicate with the zip. tried restarting phone didn't fix, any ideas???
Best Answer06-25-2017 15:14
06-25-2017 15:14
Thank you for your valuable contribution @SteveH! It's always nice seeing you in the forums.
A warm welcome to our new friend @grandmawBeth! If your issue hasn't been resolved yet and, adding to @SteveH's post; I also recommend checking out this post with more troubleshooting steps (syncing issues).
Hope this helps. Feel free to post back! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
Best Answer06-23-2017 23:50
06-23-2017 23:50
As you have tried restarting your phone without any luck I would try restarting your zip using this procedure:
Your Fitbit Zip is now restarted. You will see your tracker's version number, followed by a series of Fitbit Smilies. When you tap your tracker, it should work normally. If your tracker still doesn't work after a restart, contact Customer Support.
06-25-2017 15:14
06-25-2017 15:14
