03-11-2018 01:23
03-11-2018 01:23
I live in Australia and our date format is dd/mm/yy and I think it would be a good idea to be able to change my date format to this as using mm/dd/yy is very difficult. I am sure there are other countires in the word that use the date format dd/mm/yy.
03-11-2018 10:51
03-11-2018 10:51
You should add this to the features forum. Developers look there for ideas. If it gets the votes it could be added.
https://community.fitbit.com/t5/Feature-Suggestions/idb-p/features
Wendy | CA | Moto G6 Android
03-12-2018 14:14
03-12-2018 14:14
Awesome help @WendyB! Welcome to the Forums @Stalag138! As @WendyB mentioned, currently that setting doesn't exist. The best place to make your voice heard is the Feature suggestions board. There you can upvote for similar ideas or create your own suggestions. The suggestions with more votes are taken into consideration for new app updates or product development.
I hope this helps, keep me posted! 🙂
