04-02-2018
13:50
12:07
LucyAP
04-02-2018
13:50
12:07
LucyAP
I changed the battery on my Zip, but the display will only show for a short time and then the display is blank. I've tried reinserting the battery, but still is not working properly. Any suggestions?
Welcome to the Forums @griff121! Thanks for sharing your experience with your Zip tracker. Please double check that you have inserted the CR 2025 battery with the '+' up.
Also, I would like to recommend checking the metal spring inside the Zip's battery compartment. Sometimes your tracker will have battery issues when this is bent. Here is a picture of how it should look like:
I hope this helps, keep me posted!
