01-31-2017 20:34
01-31-2017 20:34
First day worked great on bra strap. Next two days, same placement and zero steps. I walked two miles each day. What's up with this device?
Best Answer02-02-2017 16:42
02-02-2017 16:42
@leighsfolly welcome to the forums! Well, that's pretty weird because your Zip is designed to count steps when worn on your bra. Take a look at this post with more info about it. I recommend a restart by doing the following:
Your Fitbit Zip is now restarted. You will see your tracker's version number, followed by a series of Fitbit Smilies. When you tap your tracker, it should work normally. Let me know how it goes! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
Best Answer02-03-2017 04:24
02-03-2017 04:24
That is weird I have a fitbit zip and it works, the only thing for me is that it keeps changing weird times for me.
Best Answer02-04-2017 05:45
02-04-2017 05:45
Hey there, @Vivian_awesome!
I saw your comment in this thread so I recommend trying what I suggested there and post me back with the outcome.
Best Answer02-05-2017 05:36
02-05-2017 05:36
My Fitbit zip was working fine, then stopped recording steps, time is off, etc. Replaced the battery and that didn't solve the problem.
Best Answer02-06-2017 11:59
02-06-2017 11:59
@Lakehouser thanks for joing us and for changing the battery already! Seems like all troubleshooting has been exhausted, therefore I suggest contacting our Support Team. They definitely have the proper tools to take a deeper look into your tracker's behavior. When you contact them, I recommend letting them all the troubleshooting steps you've done so far to fix it. By doing that you'll be helping them to provide you with a quick follow up. Good luck and keep me posted! ![]()
