06-11-2018
22:13
12:13
LucyAP
06-11-2018
22:13
12:13
LucyAP
I wear my Fitbit when I'm at work I don't get off of work until 2:30 a.m. my question is how do I keep track of my steps if it resets at midnight
Welcome to the Forums @Shanelee! As kindly mentioned by @Rich_Laue all Fitbit trackers reset at midnight and if you are moving it should keep track of the steps you take.
If you are referring about the time your tracker resets, at the moment there is not a option to change the time your Zip resets. As workaround some users have changed the timezone of their trackers to keep track of this steps. However, this will change the time displayed on your tracker.
I hope this helps, keep me posted! 🙂
