06-06-2018 20:03 - last edited on 06-07-2018 15:24 by LucyAP
SOUTH ..Same problem here Zip dropped from App about 4 days ago when I try and sync
get Error 400.......I spent time with Customer Service they could do nothing to help me ..
06-12-2018 15:30
06-12-2018 15:30
My new ZIP arrived in mail today Synced perfectly first time .
06-02-2018 21:39
06-02-2018 21:39
Same here FitBit needs to fix update. Downloaded it after install for to end then received a fail. Now when turned on get smiley face sticking out its tongue. I am guessing FitBit's way of saying we don't care about your tracker. Removed from account now it will not even allow it to connect to FitBit.com
06-07-2018 16:41 - edited 06-08-2018 09:30
Hey there @tonie and @South! Thanks for sharing your experience with Fitbit Zip and Support. I wanted to assure you that we take into consideration all the comments provided by our users to continue improving your experience.
Double check that you have followed the suggestions on the help article Why can't I update my Fitbit device? If this doesn't help, please try to update and setup with other compatible mobile device or computer.
@South Regarding Zip face, this is a normal behavior. The faces you see on your display will indicate your activity level. If you've been active, it will likely be an enthusiastic happy face. If you've been sedentary, it might stick its tongue out at you. It's just a fun visual to represent your recent stepping data
I hope this helps, keep me posted! 😉
06-07-2018 20:41
06-07-2018 20:41
Didnt work have tried everything ...
06-08-2018 09:33 - edited 06-14-2018 12:05
Welcome back, thanks for confirming this @tonie! In this case, I think the best option is to continue working with Support using the same case number you have. I'm sure that they can clarify this further for you.
Catch you later!
06-12-2018 15:30
06-12-2018 15:30
06-14-2018 12:09
06-14-2018 12:09
Awesome news @tonie! So good to hear that Support was able to help you to get back on track. I hope your new tracker help you to crush all your fitness goals. Please don't hesitate to post back if you need more help or if you have more questions.
Also, I'd like to encourage you to join us at the Discussions board, there you can be inspired, find some tips to get moving, eat well, manage weight, sleep better, live mindfully and more!
Give it a look! 😉
