I have notice recently (one day last week and again yesterday) that my Zip stops recording my activity during the day and just records 10 steps at 5 min. intervals for awhile (several hours yesterday) and then goes back to recording actual activity. It did this last week during a period when I was actualy jogging so it should have recorded several thousand steps as well as couple of miles of stride). All lost data. My weekly progress report is trash. What's up with that?
Welcome to the forums @mrnimble! I'll be glad to help! 😉
This is an odd situation, your Zip should not be stop recording your activity. In this case, I would recommend checking the metal spring inside the Zip's battery compartment. Sometimes your tracker will have battery issues when this is bent. Here is a picture of how it should look like:
I hope this helps, keep me posted! 😉
@mrnimble thanks for getting back to us! It could be that the side spring may be bent as a result of improper battery insertion or pressure being applied to the back housing. Please verify that there is proper contact between the battery and the battery contacts inside your Zip tracker.
You can do this by opening the battery door of your Zip, removing your battery, and ensuring that the silver battery tab located in the lower right half of your tracker is flush with the white box outline in the tracker housing. The process can be followed here. Let me know if this helps. I'll be around! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
Welcome to the Forums @achughes. ![]()
Wow, you've done and excellent job troubleshooting your Zip. If this is still not working fine. We will have to open a case for you. I noticed you contacted our support team a couple of days ago. Please confirm if the issue persist so they can check your warranty options.
I'll be around.
