10-31-2018
11:45
12:13
YojanaFitbit
10-31-2018
11:45
12:13
YojanaFitbit
Not able to sync fit bit steps to app, stuck at Looking.... status. Please help.
Moderator edit: Updated subject for clarity.
11-01-2018 12:12
11-01-2018 12:12
Hi @mjin! Please receive a warm welcome to the Fitbit Family! It's great to see you participating in our Community! ![]()
Thanks for the steps that you already try to fix these syncing issues. What model of phone are you using? You can try the next steps to fix it:
If you encounter any issue let me know with details, so I can further assist you. But I'm pretty sure that these steps will do the trick. It's important to confirm that you syncing device is listed here.
Note: Make sure your phone and Fitbit App are up to date. And for Android phones take a look of this tips for syncing from @ErickFitbit! ![]()
Let's give it a try and please keep me posted! ![]()
05:30
09:24
YojanaFitbit
11-02-2018
05:30
09:24
YojanaFitbit
Hi Yojanafitbit,
Tried steps 3-4 times, but still getting error in Bluetooth connection that pairing rejected by zip. It's very frustrating to follow steps and see same error. I've tried all the steps suggestion. But still no use. I'm getting the same error that pairing rejected by zip.
Please let me know where can I go to get the zip fixed.
11-06-2018 09:22
11-06-2018 09:22
Hi @mjin thanks for getting back. I'm not sure why you're getting that error since the restart should be working to solve that error message. What model of phone are you using? Have you tried with a different device. You can also find some tips here: Why can't I set up my Fitbit device?
I'll be around.
