01-23-2019 08:50
01-23-2019 08:50
I misplaced the tool to replace the battery on my Fitbit Zip. I used a coin like others have stated, but it is a pain. It works in a pinch, but not as easily as the tool (plus I was scratching the cover trying to get the cover up). I contacted Customer Service and they don't sell this tool by itself, which I thought was odd. Did anyone find anything else that works better than a dime? Or, potentially have the tool to sell?
01-24-2019 17:09
01-24-2019 17:09
Hello @Jenny0123, it's good to see you around in the Community forums for the first time.
As you've mentioned previously, and was also confirmed by the customer support team, the flat black tool that came with your Zip is not sold on the online Fitbit store or retailers. If you've lost the tool, the most recommended options are precisely a coin or a pen knike to remove the cover.
Thank you for sharing your feedback regarding the option to have the tool available for sale; these comments are always helpful to continue improving products and services.
Keep on stepping. ![]()
Best Answer12-15-2019 16:07
12-15-2019 16:07
Hell-o, could you tell me where the battery is? the four gold dots or the big blackthing with 4 clear squares?
Best Answer01-12-2020 13:17
01-12-2020 13:17
what does the battery replacement tool for my zip fitbit look like
Best Answer01-12-2020 13:55
01-12-2020 13:55
I use a quarter and it works well..
Best Answer01-12-2020 13:56
01-12-2020 13:56
I use a quarter and it works well..it’s my only option for opening the battery compartment..
