12-24-2017 07:03
12-24-2017 07:03
I have the same issue as a lot of others with the battery in my fitbit zip. I put a new battery in 2 days ago and yesterday I received a message that my battery was almost dead. This morning it is in the yellow. If I take the battery out and reinstall it then it's back in the green. When I check the "dead" batteries with a meter they usually read around 2.87 volts so they are far from dead. I have talked to tech support about this and they said the engineers are working on this. I am just about ready to toss my zip for something else. Anybody got any suggestions? Thanks Tracy Knight
Best Answer12-26-2017 12:22
12-26-2017 12:22
Hi
From dear @KateFitbit in this thread
I've been notified that there are reports of Zip battery draining quickly on iOS version 2.41.1 and our team is currently investigating. If you are experiencing this, we recommend disabling all-day-sync for now. I'll update this post once I hear more. Thanks as always for your patience and understanding.
Turn off All-Day Sync:
Hope it helps
