01-27-2016 17:15
01-27-2016 17:15
Best Answer01-27-2016 19:56
01-27-2016 19:56
i am having the same problem..i got my fitbit zip today and i cant sync it to my phone or computer
01-27-2016 19:56
Best Answer01-29-2016 06:20
01-29-2016 06:20
02-01-2016 04:08
02-01-2016 04:08
02-06-2016 21:05
02-06-2016 21:05
I am having the same problem. This is a really bad deal. There is no one out there to help. Is there a better tracker on the market. ? I am ready to chuck this one
02-14-2016 12:46
02-14-2016 12:46
I tried everything from reinstalling the program to removing the battery etc. It wouldn't sync with the Zip setting on top of the dongle. I found out that if I tell it to sync, it says to try again and again. I found that, if I try it again, or just after it asks to sync, if I just drop the Zip onto my mouse pad from a couple of inches it will alway sync with in a very few seconds. I am wondering if someone else could try that and see if it helps them sync the Zip
Best Answer03-17-2016 17:01
03-17-2016 17:01
try garmin,they might have a tech support as good as their gps sales have,they where the first in the buisness
Best Answer03-17-2016 17:58
03-17-2016 17:58
I can't sync either, not to phone or computer. Anyone know what the problem is?
Best Answer03-17-2016 19:08
03-17-2016 19:08
I contacted the fitbit chat for help and they fixed my syncing problem
Best Answer03-19-2016 06:59
03-19-2016 06:59
what did they do? I can't sync to the comuter or phone (not sicne January?)
Best Answer04-21-2016 09:45
04-21-2016 09:45
Sorry, Fitbit, but his is way too big a problem to keep ignoring it!. . Why can't yopu just put a "SYNCH NOW" button on the dashboard. This is a very frustrating problem. I can't get mine to synch - have had this problem all along. Then a while later I turn it on and it has synched. This is SO FRUSTRATING, especially when you change time zones!!!!!
Best Answer05-09-2016 20:09
05-09-2016 20:09
My fitbit wont sinc to my phone or computer. the sinc button is gone
Best Answer05-09-2016 20:12
05-09-2016 20:12
I'm having the same issue my sinc button disappeared yesterday. tried uninstalling, both computer and phone. I even restarted the fitbit but no luck.
Best Answer05-10-2016 07:43
05-10-2016 07:43
Best Answer05-10-2016 18:32
05-10-2016 18:32
Best Answer05-11-2016 07:20
05-11-2016 07:20
Best Answer05-11-2016 07:24
05-11-2016 07:24
Best Answer05-11-2016 07:33
05-11-2016 07:33
Best Answer07-25-2016 16:17
07-25-2016 16:17
Anyone out there know what is going on??? My fitbit hasn't synced since last Thursday and I'm really starting to get PO'd!!! Sent messages and questions, but no one has bothered to answer them!!!!!!! Hello fitbit people...you're supposed to be helping us not ignoring us 😛
10-21-2016 18:42
10-21-2016 18:42
solved the fitbit sync not syncing with my zip.
found that if you tap your zip when you click on sync------make sure your zip shows the TiME.
works for me
