Hello @Juhurst27
Take a look at the Zip area where you can find the user manual and related help articles. click to go there
You'll need to use your battery door removal tool (or a coin) and have a fresh button battery to insert.
Welcome to the Forums @Juhurst27! It looks like @Odyssey13 gave an awesome suggestion. I'd like to invite you to mark @Odyssey13's post as the solution.
Marking posts as solutions is a great way of thanking another community member while also highlighting their solution so that it may be discovered more easily by other community member facing the same questions or issues as you. You can read more about Accepted Solutions here.
Thanks for posting in the Community!
