06-04-2018 07:04
06-04-2018 07:04
I recently got a fitbit zip for free through my work. I tried to set it up and have some questions. Am I supposed to take the little slip of paper out of the zip before I put the battery in? I put the battery in and closed the zip door but my fitbit did not come on or anything like it was supposed to. it may just be a faulty battery but I just received my zip last week and opened it on the same day.
Best Answer06-04-2018 07:36
06-04-2018 07:36
Welcome to the forums @bmad93
Here is a link to the Zip user manual and related articles - click to go there.
I'd remove the piece of paper, as it's probably keeping the battery from making contact.
Let us know what happens.
Best Answer06-04-2018 15:16
06-04-2018 15:16
Welcome to the Forums @bmad93! Thanks for sharing your experience with your Zip tracker. As @Odyssey13 mentioned you need to remove the paper inside your Zip to ensure that there is proper connection.
To setup your tracker you can check the Zip User's manual or the help article How do I set up my Fitbit device? Also I'd like to kindly advise you to vote for @user’s post. Votes contribute to a positive reputation in the community. Earning votes and giving votes also factors into the Community Rank and the possibility to land a spot on the Most Helpful Authors list, located at the bottom right of every discussion category page.
I hope to see you around more oFten! 🙂
