06-15-2018
15:03
09:30
LucyAP
06-15-2018
15:03
09:30
LucyAP
When I sync my zip to the app it adds 500-1000 steps. I have tried deleting/adding back my zip. I have deleted/redownloaded the app. I have restarted my devices. I use a Samsung Galaxy 8 and an ipad. I have used 3 different zips. (I even got a new zip yesterday and the issue persists). This has been occuring for about 2 months. How can I fix this so my step sync is accurate?
Welcome to the Forums @IndyBoiler! Thanks for sharing your experience with your Zip and the Fitbit app for Android and iOS. I appreciate all the troubleshooting you performed before posting.
Factors such as tracker placement, and stride length can all affect the number of steps recorded. For more information about this you can check out the help article How accurate are Fitbit devices?
Also, if after taking these factors into account you still think your tracker is significantly undercounting or overcounting steps, please try a step test:
If your tracker counted less than 100 steps or more than 100, please let me know and we'll see if we can investigate further.
Also, if you are using MobileTrack and your tracker at the same time keep in mind that we recommend using MobileTrack only when you forget your Fitbit device at home.
Keep me posted with the outcome! 🙂
Welcome back @IndyBoiler! Thanks for sharing your experience with your Fitbit Zip. To further assist you, I've created a Support case on your behalf. I'm confident that Support can help you to determine if the discrepancy comes from the app or tracker.
You should receive an email from Customer Support at the email you used to register with the Community forums.
Keep me posted if you have any other question.
