Awesome suggestion @Odyssey13! 😉 Welcome to the Forums @Lulusmom! Zip will go to sleep after approximately 20 seconds and it will remain off until moved.
If @Odyssey13's suggestions helped to resolve your issue, I invite you to mark @Odyssey13's post as the solution. Marking posts as solutions is a great way of thanking another community member while also highlighting their solution so that it may be discovered more easily by other community member facing the same questions or issues as you. You can read more about Accepted Solutions here.
Keep me posted! 😉
