07-18-2017
10:44
17:17
LucyAP
07-18-2017
10:44
17:17
LucyAP
Zip not syncing it showing on the zip but not on phone
Moderator edit: title for clarity
Best Answer07-18-2017 15:03
07-18-2017 15:03
I'm having the same problem...what's up?
Best Answer07-18-2017 18:58
07-18-2017 18:58
Nice to see you here @Netty2 and @Christysuz! @Netty2 Please check this tips to fix your syncing issues. And also, you may try restarting your tracker to see if it's working correctly.
@Christysuz Can you please try restarting your Zip and checking the inside spring. Sometimes your tracker will have issues when this is bent. Here is a picture of how it should look like:
Keep me posted with the outcome! 😉
