01-25-2017 07:13
01-25-2017 07:13
Something that may help other women with accuracy issues. I haven't used mine in a while, but I got it from my employer for free as part of a get healthy initiative. I found it logged waaaaaay more than I was actually moving when on my hip, but for what ever reason, (and don't laugh, this worked), attaching my zip to my bra about half-way down the front of my boob gave me the best accuracy. I tested it and it was always accurate within 20 steps, as it counted bending over a step, but I guess that is a movement that should count towards calorie counts too. I worked as a stockperson in retail, and was on the go constantly and consistently. I haven't updated my zip to the site though. I should connect it. lol
01-30-2017 14:29
01-30-2017 14:29
A warm welcome to our new friend @DeeDee1976! Thanks for sharing what best works for you and actually your Zip is designed to be worn close to the body. A shirt pocket, bra, pants pocket, belt, or waistband are all ideal places to wear your Zip.
Always use the silicone holder when clipping Zip to a bra or waistband; Zip should not be worn in close contact with the skin. For this reason don't wear Zip inside your bra. Thanks again for sharing!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
01-30-2017 14:29
01-30-2017 14:29
