01-12-2016 08:11 - edited 01-12-2016 08:16
Hello,
I am having issues syncing my Fitbit Zip to my Android app. I have rebooted the phone, uninstalled and re-installed the app, and restarted my Zip but nothing seems to work. My bluetooth finds the Zip, but, when I connect to the app, it tells me the tracker cannot be found. That said, I have no issues syncing on my desktop computer when I am home. Why can I not sync on my phone? I have a Samsung Galaxy S4. I should note that I have successfully synced my Zip via the app on my phone in the past. The problem seems to have arisen in the last few weeks.
Thank you.
08-12-2016 07:57
08-12-2016 07:57
Hey you @SunsetRunner, I'm glad to see you around the Fitbit Community
! Have you followed what I've suggested in this post? Have you made sure that the Dongle is being recognized correctly?
08-12-2016 08:25
08-12-2016 08:25
Best Answer08-12-2016 16:07
08-12-2016 16:07
Best Answer08-12-2016 21:45
08-12-2016 21:45
Best Answer08-13-2016 08:59
08-13-2016 08:59
Thanks for trying the suggestions I've provided @SunsetRunner! My best recommendation would be to get in touch with Customer Support directly so they can do a deeper investigation to see where the issue is coming from.
Did you do the factory reset @Rockman1973? Well if that's the case, we don't recommend the factory reset until you've contacted support and they guide you through the steps (they know when a factory reset is needed).
See you around guys!
Best Answer08-13-2016 09:19
08-13-2016 09:19
Best Answer08-16-2016 07:53
08-16-2016 07:53
You're very welcome my friend @SunsetRunner, don't forget to keep us posted!
Best Answer08-16-2016 11:46
08-16-2016 11:46
My problems also started on 8/11/16. My zip is not syncing with my android app or my desktop. Also, the time zone displayed on the zip changed from Eastern to Pacific time even though my settings indicate it should be Eastern. The last sync was Thursday 8/11/16 at 10:16 p.m.
Best Answer08-18-2016 07:21
08-18-2016 07:21
It's great to have you here @mmt123, well my friend if you have tried all the recommendations we've shared in this thread without luck, my best suggestion would be to get in touch with Customer Support directly so they can do a deeper investigation into this and see where the issue is coming from.
Just don't forget to mention the steps you've done so far to avoid getting the same ones.
Good luck my dear!
Best Answer08-18-2016 11:03
08-18-2016 11:03
Best Answer08-19-2016 07:41
08-19-2016 07:41
I'm pretty sure they will @mmt123
Don't forget to keep me posted my friend!
