01-24-2017 08:07
01-24-2017 08:07
Unable to wake up fitbit
Best Answer01-25-2017 05:10
01-25-2017 05:10
It's great to welcome you @Lagliata. The reason why your tracker is not turning of is because sometimes the side spring may be bent as a result of improper battery insertion or pressure being applied to the back housing.
Please verify that there is proper contact between the battery and the battery contacts inside your Zip tracker. You can do this by opening the battery door of your Zip, removing your battery, and ensuring that the silver battery tab located in the lower right half of your tracker is flush with the white box outline in the tracker housing.
Let me know how it goes. ![]()
01-25-2017 05:10
Best Answer01-25-2017 14:58
01-25-2017 14:58
01-26-2017 03:03
