03-17-2016 04:54
03-17-2016 04:54
Best Answer03-17-2016 08:17
03-17-2016 08:17
Best Answer03-17-2016 08:31
03-17-2016 08:31
Best Answer04-04-2016 09:56
04-04-2016 09:56
Welcome to the Fitbit Community @keljowright @Josen_E
! I'd recommend trying to follow the steps posted here to solve the syncing issues.
Have a great day!
Best Answer01-17-2017 19:41
01-17-2017 19:41
I now have an Alta and switched phones. I gave it to my son and im trying to connect it to his iPhone 5 and it won't sync. I did the reset thing and that didn't help either. This is frustrating now. It wouldn't even sync to an iPad.
Best Answer01-19-2017 04:36
01-19-2017 04:36
Hey you @Josen_E! If guy are switching phone, try doing these steps that @Thray has shared. When you are in the step No. 4, keep in mind that the set up process should be on your son's iPhone 5.
Let me know if this helps!
13:02
07:14
01-19-2017
13:02
07:14
That never worked either
Moderator edit: removed personal information
Best Answer01-20-2017 07:20
01-20-2017 07:20
Thanks for the update @Josen_E! My best recommendation would be to get in touch with Customer Support directly they'll be more than glad to give you a hand on this.
Don't forget to mention the steps you've done so far to avoid getting the same ones. You'll be in good hands!
Best Answer01-20-2017 08:20
01-20-2017 08:20
I'm dealing with the same issue, which is why I'm here.
Best Answer01-21-2017 06:38
01-21-2017 06:38
Hey my friend @winnie95! Have you followed the steps I posted here?
01-21-2017 20:26
01-21-2017 20:26
Tracker won't sync with phone
Best Answer01-26-2017 04:47
01-26-2017 04:47
Hey you @Knitter1, welcome here!
Have you made sure if your tracker is properly linked to your account? Are you seeing the Zip icon at the top of your Fitbit app?
If so, please try following the steps I posted in one of my previous post (here).
If you don't see the icon, try setting it up as a new device by following these steps:
Let me know if you need further help!
