02-08-2016 09:21
02-08-2016 09:21
Best Answer02-08-2016 09:33
02-08-2016 09:33
Hello @B_Z1,
Welcome to the community!
It may be an issue where the terminals are not making a good enough contact with the battery. I would try two things:
Though keep in mind that the battery may legitimately be dead. I buy them in bulk at Amazon (you can get them for under $1 each).
If your battery is drained, then by all means replace it. You'll need to do this to get it back in working order. If it's draining faster than it should, then let us know and we can help you diagnose why that's occuring.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
02-08-2016 09:33
02-08-2016 09:33
Hello @B_Z1,
I hope this helps.
02-11-2016 22:32
02-11-2016 22:32
02-16-2016 22:02
02-16-2016 22:02
02-17-2016 15:56
02-17-2016 15:56
As the other two folks responded - this worked like a charm - thanks!
02-27-2016 08:05
02-27-2016 08:05
11-03-2016 09:07
11-03-2016 09:07
I faced similar problem for the past one month I tried replacing the battery with new one but did not help.
I felt that contact between battery and terminal was not properly held. I placed a folded piece of paper (with 4 folds)over the battery and then closed the cover. For the past one week my Zip is working well without missing time or steps.
R S Raghavan
11-07-2016 04:08 - edited 11-07-2016 04:08
Hi there @rsraghavan, welcome aboard to our Community and thank you for sharing with us you experienced something similar, although @PureEvil solution is great for these type of issues.
This issue is common with devices that held this type of battery connection, but the bright side is your tracker is working again.
For anything else you can find me here and stay awesome.
11-19-2016 23:16
11-19-2016 23:16
Thank you. Perfect short-term fix.
Best Answer11-23-2016 14:04
11-23-2016 14:04
@AW2304 welcome to the Fitbit family! Thanks for letting us know that this workaround did the trick for your buddy!
I now invite you to visit our Discussions section. In there you'll find all sorts of interesting topics and I'm sure you'll make lots of Fitbit friends!
Cheers!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
11-29-2016 20:56
11-29-2016 20:56
I can't get battery in
Best Answer11-29-2016 20:57
11-29-2016 20:57
can't get battery to snap in so I can put lid on
Best Answer11-30-2016 07:19
11-30-2016 07:19
Hi there @speedy88-cork, welcome aboard to our Fitbit Community. Make sure the battery you are using a 3V coin battery CR2025.
Also like it was recommended before, review that the silver contacts are align and making good contact with the battery.
Let me know how it goes, I'll be here if you need more help.
11-30-2016 16:58
11-30-2016 16:58
I got my fitbit zip on 9/21/2016 and was working amazing, would randomly tell me the battery was real low then go back to full battery. When it said low battery for more then 5 days I changed it with a brand new battery and that's when I've been having problems, when it dies connect it says full battery so its not a faulty battery. I do on average 10,000 steps or more a day as my job is me always on my feet and today it said I was less then 3K. When I tap it it does the normal changes then shuts off, I tap it some more and then a 1 . Comes up on the tight side and comes back on, then shuts off again. I've tried taking the battery out again and again to reset it and its not working. I've had this for less then 3 months and unfortunately can't afford another fitbit but I love mine. I use it every single day and I don't know what to do to make it work again. Please help????
Best Answer11-30-2016 17:22
11-30-2016 17:22
So just after posting this, it won't turn on anymore. If I tap for awhile it will for a second then shut off again. I even put in another new battery just to be safe and its still not working. 😔😔
Best Answer11-30-2016 17:27
11-30-2016 17:27
I just posted that I was having problems and I'm so glad I saw this. It fixed mine too 🙂 thank you!!!!
12-01-2016 04:50
12-01-2016 04:50
Hello @Babygadgetz, let me give you a warm welcome to our Fitbit Community. Note that I have merged all your posts on this thread to keep our Community sorted and focus the issue on the same conversation.
I'm glad to hear you were able to fix your Zip, by following the suggestions from @PureEvil.
If you have more questions, feel free to let me know.![]()
