07-27-2017 09:20
07-27-2017 09:20
This Zip is almost 2wks old and the battery doesn't last for more than 3 days. I purchased this at a Weight Watchers location.
Best Answer07-28-2017 18:54
07-28-2017 18:54
Thanks for stopping by @DZeppelin! This sounds odd. To make sure that your tracker is working correctly, please restart it.
Also, sometimes your tracker will have battery issues when this is bent. Please check this post by @vomitofthemind to check a tip on how to fix the contacts inside your Zip tracker.
I hope this helps, keep me posted! 🙂
